HELP TO IDENTIFY YAMAHA 40 PRECISION BLEND
czuniga08
HELLO,
ANY ADVISE WOULD BE GREATLY APPRECIATED. PICKED UP A 40HP YAMAHA PRECISION BLEND. I TRIED LOOKING FOR SERIAL OR MODEL NUMBER BUT SEEMS THAT TAG WAS REMOVED FOR WHATEVER REASON. I PICKED IT UP FOR 150.0 DOLLARS ACCORDING THE GUY I BOUGHT IF FROM IT HAD BEEN SITTING FOR YEARS. AND FLYWHEEL WOULD NOT BUDGE. SO GO IT PREATY CHEAP. POURED SOME OIL INTO THE PLUGS AND SURE ENOUGH COUPLE OF DAYS LATER IT TURNED. I WAS ABLE TO CHECK COMPRESSION WITH HARBOR FREIGHT TESTER AND IT CAME IN AT 120 ON ALL 3 CYLINDERS. HOWEVER I DID NOT HAVE ANY SPARK. I NEEDED TO FIGURE OUT YEAR AND MODEL NUMBER TO TRY TO GET SOME MORE INFO ON PARTS ON IT,, THERE IS NUMBER STAMPED ON THE BACK THAT READS Y-I 6H400 AND AN NUMBER ON THE STARTER THAT READS 6H4-81800-10
czuniga08
Hello,
My bad buddy, i didn't realize my caps were one,, didnt mean to be rude or disrespectull to the forum...
