Help.... the ethanol in my gas ate up my doel fin... does it really do anything????
Maclin
Re: Help.... the ethanol in my gas ate up my doel fin... does it really do anything??
Yes, the ethanol raises the octane rating while lowering BTU's, quite a feat.
or did u mean the fin :laugh:
smokeonthewater
both will make Pennzoil out perform Quicksilver oil
Maclin
Was that fin synthetic or dino?
Starcraft5834
:laugh:
only if it was an outboard vs an I/O. :lol: :popcorn:
Maclin
Scott, you are not thinking of the rudder mounted fin for inboards, rare but ineffectual. :)
I was actually thinking the one for the Johnyrude-hond-zuki-maha-hatsu-cery vs the merc-enta-saders brand.
Brian 26
Did you have your trailer lights unplugged before you backed into the water?
Maclin
Also may need anodes on the plastic, just sayin'... :laugh:
dont forget a new can of prop wash
Home Cookin'
It was probably the salt water. If you dip your motor in for more than 15 minutes without rinsing, it will all fall apart. Especially a frsh-water Yamaha.
If not that, the most likely the transom saver caused the dolphin doelfin to degrade. or not having enough chain on your anchor line.
Frank Acampora
Oh, Come ON guys! Stop joking about it! We all know the whale tail wore off because he had the engine mounted too low, thus dragging it through the water at speed.
Maclin
I fogot about the galvanic molecular level transom saver to fin reaction, yikes. Only depleted uranium is worse from what I understand.
Maclin
Might have been fresh water piranha. It could happen.
Home Cookin'
Or the HP of the motor was 5 above the limit on the boat tag.
only when propelled thru the barrel of a 155mm howitzer
Maclin
Quagga, their impact is often underestimated.
NYBo
42 :cool:
Campylobacter
Just rub some vaseline on the fin, you should be fine.
