help! tach issues
DJ87
Today is my first time using these forums and i must say being a first time boat owner i have learned alot. I was trying to figure out how to get my tach to work in the force engine forum and saw a posting saying that you might know what to do. what i have is a 20 foot 1987 bayliner with a force 125 outboard. The boat had been neglected and i had to rewire, carpet and upholster it. the dash had been altered and cut out to fit only a fish finder.i dont know what was there before but i removed all that and made a new dash plate with 4 gages, fuel, speed, tach and volts. My tach doesnt work right and reads much higher then it should. I went through the wire schematic and have it wired correctly into the strip on the side of the engine , on the terminal that says tach and has a purple wire going to my rectifier. I read somewhere tonight that it appears i have a 20 pole alternator and its very outdated. They then go on to say that todays systems are a 12 pole and thats why the new tach is all over that place. Is there something i can do to my current tach wiring to get it to work? If not do they even make a tach that works for my boat?:confused:
Barnacle_Bill
Re: help! tach issues
Yes, you will need a special 20 pole tach. Nothing can be done to the ones made for a 12 pole stator.
Silvertip
Honorary Supreme Mariner
What everyone says is true. But the reason this is true is because the tach works from pulses from the charging system. Your engine has a 20 pole stator that produces 10 pulses per revolution of the engine. Most current engines have 12 pole stators that produce 6 pulses per revolution. Other variations were 10 pole (5 pulses). Since your engine is applying 10 pulses to a tach designed to handle a maximum of 6 pulses you can see why it is reading much higher than it should. Your only solution (at least economically) is a tach that can handle 10 pulses. Great Lakes Skipper is the place to go for this.
DJ87
thanks guys, i have ordered one, merry christmas!
