Help starting a 1959 35 hp bigtwin
nashwinter123
Hi. Got a beatiful bigtwin the other day (beautiful to me atleast). Shes beat up and missing some thing I think. It's electric start but theres no key holes. I have the controls to the motor but didn't grab the key starting stuff. Any idea where i can get on for either inserting on the motor or to attach to a dash? Thank you
lindy46
Re: Help starting a 1959 35 hp bigtwin
Check Ebay or go to AOMCI.org and place a want-ad on their Webvertize.
nashwinter123
Do you need the key to start it? It has a pull cowrd.
bktheking
No just pull it over , it will start without a battery. The easiest thing to do it to get yourself a marine solenoid and wire it up to a key switch.
nashwinter123
Can you tell me how to do that? Only being 16 and have been only working on outboards for three years comes with some disadvatages...... I thought there already was a selionod in there.....
bktheking
I don't know what's on your motor, why don't you post some pics?
nashwinter123
Ok well i got it started.... amazing can't believe it...... atleast 20 plus years and all it tuke was some new spark plugs.... I started it very improperlly the first time (got a battery hooked jumpers to it... put the neg on the block and held the pos on the starter).... Pull start works great now. Have a video of it but Ill throw some pictures of the part on here. Give me a few seconds.
nashwinter123
The thing!
bktheking
So it has a solenoid albeit looks original. Use it or change it , that's if it even works. You will need to wire it up, do you need info how?
1946Zephyr
Here is a good wiring diagram to work with that motor.:cool:
nashwinter123
Thank you very much. I've been looking for that picture. Can I just make that? Or more helpfully could I just buy a wiring kit and where. And i think the solenoid is dead.
Thank you
bktheking
Make it and keep it simple, I built a box for my neighbours 40 using a utility electrical box (plastic) , marine solenoid, cables and wiring from an auto store, inline fuse and a 6 pole marine keyswitch.
nashwinter123
So it doesn't need to be the exact ignition switch or solenoid?
tootallofwa
It has to be a "Marine" switch and solenoid. They work different than their automotive counterparts. (pun works well here).
Terminals on ignition switch connect the 2 black ignition wires together internally in the "off" position to kill the motor and connect the white starter solenoid wire to the green battery wire, in "start" position to crank it.
DO NOT CONNECT THE BATTERY TO ANYTHING ON THE MOTOR,
Only to the solenoid. The solenoid then connects to the starter.
