horizonlawn
Thread starter- Joined
- Mar 26, 2009
- 13
I've got a 02 landau elite 22.5 ft tritoon, came with a 90 hp merc 4 stroke, went pretty well with the 90, could do about 28 mph empty, but loaded it would fall on its face pretty bad. so i spent the summer looking for a 150, and finally found one. its a yamaha 150 fourstroke, got the motor on the boat and ran it with a 14 x 19 prop, a little big but it came with the motor so i figured i would try it to get an idea of where i needed to be. so i ended up trying a 15 x 15 solas aluminum prop which seems to be close, its running at 5400 rpm and 37 mph. which isn't to bad, but it seems like i should be into the 40's with this motor. the thing that i'm now concerned about is the extra weight in the back of the boat, a little over 100 lbs seems to really squat the back of the boat in the water, and even when i'm wide open the but still doesn't seem to come up and out like it should. this was one of the early tritoons where they weren't extending the center tube past the back of the boat, its mounted like any standard pontoon would be. does anyone have any experience doing the extension of the transom, would the extra flotation in the back help me, or is it more work than its worth. the boat goes good, but if i can get a little more out of it its worth the effort, also it seems like i should be able to pull a 14x 17 prop with that motor, but based on my rpm with the 15" i dont think i could, which suprises me because i had a 14 x 13 on my 90 hp. any help would be great thanks
