Silvertip
- Sep 22, 2003
- 28,771
Re: HELP RODBOLT
Are you putting the needles in the correct way? I've seen it done wrong many times. Next time you have the carb off, with the float, needle and seat installed, turn the carb upside down and then blow into the fuel inlet. If you can blow through it, it still isn't sealing and you either have it assembled wrong, things are binding, or it still is not clean.
