Hello folks,<br /><br />I want to remove the window off my fletcher but... The windscreen is bolted down but it's all rusty. I tried to removed one bolt but this one brake off. This i what i would do: Cut all the bolts of break them off. Than you can take the windscreem off i guess. The problem is how to reinstall the windscreen? I thought when you take out the glass you have some space to fit new bolts or to rivet or screw the window down and build it up together with the glass and frame. Is this possible? WIll there be space to do this. How are these bolts fitted in the frame? Does somebody know this? <br />
