Help removing LU & Parts for '87 Force 35
Xchange
I'm looking for motor mounts, water pump impeller and Lower unit seals for an '87 Force 35.<br /><br />Any help would be appreciated.
rickdb1boat
Re: Help removing LU & Parts for '87 Force 35
Impeller:<br /><br /> web page <br /><br />Gearcase seals:<br /><br /> web page # 18-2639<br /><br />Don't know about the mounts. Maybe a dealer..
roscoe
oops, you beat me.
Xchange
Awesome. Thanks all for you help.<br /><br />FYI, I also found an incredible resource for parts on MerCruiser Parts .<br /><br />Now I'm having a bit of trouble getting the lower unit off of the engine. Appears to be stuck. I'm a bit shy to pry or yank on it too hard for feer of damaging the water pump. I made sure the shifter is disconnected, removed the lower mounts, even tried to separate each section to no avail. Any ideas?
roscoe
MercruiserParts is a Mercury dealer, and usually has parts 10% cheaper than MercuryPartsExpress.com.<br /><br />Are you getting any movement out of the lower unit?<br /><br />There are 4 bolts holding the unit on.<br /><br />And you have to drop the unit a little to remove the cotter pin and coupler pin that connects the two sections of the shiftshaft.
Xchange
Hey all, I've started a new thread for this.<br /><br />It's here.... New thread...
