Help! recoil is kicking my butt
divebomber
I have a johnson jw-10 and I can not get the recoil spring to wind up and pull the rope in, I can wind it about five revolutions ccw put the rope in and it starts to retract it but you have to almost spin it cw t9 get it to go all the way in, and once it's in and you pull it out it feels like it's binding or something. Anyone know what I'm doing wrong and can help, just got all the parts to rebuild this gem but wanna get the recoil in order first, only thing I thought it could be is the recoil spring is dry I didn't know if there should be grease on it or not, any help is greatly appreciated and if anyone had a Manuel for these motors would be great thanks
F_R
Honorary Supreme Mariner
Grease the spring. Then wind it up all the way and back off one turn. Now install the rope and handle. Note: there is a small hole in the rope pulley. Find a nail or something that will fit in the hole and set aside. After you wind it up and back off a turn, stick the nail in the hole. That will keep it from rewinding and you will have all day to install the rope.
divebomber
Also I'm gonna be rebuilding the carb,how ate you suppose to get the Welch plug out
gm280
If you seriously need to remove the welch plug, and lots of folks don't unless there is a real need to do so, use an awl or even a small nail to puncture the disk and pry it out. But I'd only remove it if it was seriously giving me a problem after rebuilding the carb and still have an issue. However do disassembly most everything else and use spray carb cleaner and compressed air to verify all passages and slots are clean and clear before installing a carb kit. JMHO!
divebomber
Ok yea I thought I've read that everyone says to replace it I don't even really know what it does when I cleaned the carb the first time I d8dnt see how you could get at it to clean it
F_R
There is a large cavity under that plug, with some very small holes in the bottom of it. The idle fuel passes through those small holes. The only reason for removing it would be to clean those holes, if necessary. It usually isn't necessary, but if you ignore it, that might be the one time it is necessary. Your choice. (Feeling lucky?) Personally I don't remove it unless there is a good reason to, like won't idle.
oldboat1
firm believer that you shouldn't fix what ain’t broke, but if I'm installing a carb kit and know I have the right sized welch plug, I go ahead and replace it. In addition to cleaning out the openings FR describes, I like to screw in the needle while the plug is out as a test, so I can check the fit and make sure I'll be seating the needle properly. If you are new at it, it’s good to get the feel of seating the needle so you don’t later over tighten and break it —-- also to actually see where the needle fits.
Just carefully drill a hole in the existing plug, being very careful not to drill down to the carb body. Pop out the plug with a punch, drywall screw, sm Phillips, etc. To reseat the new plug, carefully but firmly tap it in place (I use a metal dowel). It’s an aluminum expansion fitting. Some folks use nail polish or something similar as an additional seal, but I haven’t found that necessary.
