iauctionexpress
Thread starter- Joined
- Jun 17, 2005
- 4
Hi,<br />Saw another post describing exactly this problem. Fortunately for him the problem mysteriously went away, so nobody contributed anything to the post.<br /><br />Here is post I made on the Nitro Owners site. I need all the help I can get
<br /><br />Looking for some input on a problem I have and will try to explain it the best I can. I would not make a good mechanic and its my first boat(98' Nitro LXS Mercury Force 120), so I apologize for my lack of terminology. Boat is going to shop on Tuesday for checkup, but this is bugging me and I want to maybe get an idea of what is going on here before Tuesday. <br /><br />Here goes....<br /><br />Hooked all positive and negative leads off motor and accessories to battery. The battery is fully charged. Tested lights, bilge pump, horn, etc. everything here is fine. Tested 2 trim/tilt points, up/down button on front bow and up/down switch on gear shifter...nothing is happening. I was told a third trim/tilt point should be on the motor, but I have yet to find it.<br />I wan't to concerned at this point, but then I tried to bump the motor, nothing happens, not even a hint of a start came from the motor. Now I am real concerned so I start tracing wires, looking at fuses, etc. <br />Located 20Amp fuse on side of motor, it is good. <br />Used a voltage tester and showing 12v going into starter.<br />I traced the trim/tilt motor wiring(1 blue and 1 green) into what I believe are two relays. The two red wires also going into the relays are coming of the positive terminal on the starter. Pull relays apart and verified voltage coming across the contact parts of the red wires.<br /><br />This is as far as I went. Pretty much a dummy here being curious.<br /><br />Have I given you anything here to help you all give me some input? The problem to me seems to be electrical. Is it odd that I'm not able to trim/tilt or get a single crank from the engine, and is it definately related? I sure hope someone out there with maintenance background or even someone who ran into this problem can relate any info to me. It would be very much appreciated.<br /><br />Thanks,<br />William Johnson<br />iAuctionExpress.com
