Help please
basstanker
My dad gave my husband a 196? 7.5 h.p. Wizard outboard motor. Serial # C7EB 1440 Model # MLM6908B Any info,including adjustment settings,fuel ratio,ect. is greatly needed.
steelespike
Re: Help please
6908 is a 60-62 made by Scott/McCulloch 3/8pint of TCW3 rated oil per gallon If you can pin it down to 62 1/5 pint will work.
H10J plugs set at .035, points set at .020.early motors use a Tillotson HC8AX diaphragm type carb or Marvel-Schebler SUM.You may find a after market Scott/McCulloch manual at the library or perhaps on ebay on cd.
