Help Please Johnson Seahorse 5.5
Spur
I got a Johnson Seahorse 5.5 HP.<br /><br />Im going to use it on a duck boat.<br />It is a model CD-16 and has a serial number like 1946283.<br /><br />What year is it? Its clean as heck I havent fired it up yet. I have changed the plugs, lower unit oil and lubed it. What else should I do before I make noise with it? Thanks, Chris
JB
Re: Help Please Johnson Seahorse 5.5
Howdy, Spur. Your engine is a 1959.<br /><br />Use 24:1 fuel mix , Champion J4J plugs gapped at .030, and gap the points at .020.<br /><br />Red sky at night. . .<br />JB :)
Spur
I gotta ask....<br />How in the heck did you figure that out?<br /><br />Those numbers dont make any sense to me.<br /><br />Will it be a good engin being that old? It appears to be in awesome condition.<br />Thanks alot
Spur
Also, I noticed some sites for older merc parts, do you know of a site for older Johnson parts?<br /><br />Thanks x 3
Spur
One more thing (for now)....<br />Is there a site that might show a schematic of the motor so a dummy like me can see what is what? :confused:
JB
Hi, Spur. I didn't have to figure it out, I looked it up in my old Johnson Service Manual.<br /><br />You can probably find a manual at a good Public Library.<br /><br />There are a number of sources for parts. Many Johnson Dealers still have, or can get, them.<br /><br />Twin Cities Outboard, in Minneapolis, has every part known to man.<br /><br />Red sky at night. . .<br />JB :)
Spur
I made a mistake on the serial number....didnt know if it mattered.<br /><br />The number is 19432386 it is a CD-16 :D
alcan
Hi Spur.<br />Those 5.5hps are great little motors. I used one for years until I got stupid and sold it. I would pull the fly wheel,check the coils for splits and cracks, clean the points. Then take carb apart and clean it. I'd also install a new water pump empeller, pull prop off, check for fishin line, greese prop shaft. Now these older rigs use a presure fuel system. So you need to pay special atten. to the tank, hose and connector. All gaskets, o-rings need to be in good shape. Like J.B.Cornwell said 24:1 on the mix. Don't short the oil and it might run for ever, maybe longer. If you have problems with the tank,repair it. A good tank and connector is worth more than the motors they run (in my area).Have fun hunting.
Spur
Hey great info. Now I have more questions if I may :) <br />...and yes I am not that boat smart so here goes.....<br />where are the points, if Im lookin at the motor from the front.<br /><br />and how would I take the fly wheel off? It that the houseing that the pull cord is in?<br /><br />Sorry for the dumb questions.
Spur
OK, I can tell ya whatever you wanna know about bull riding and bowhunting but outboards are not my best subject....yet!<br /><br />I took off the thing that has the pull cord attached. The round thing under it looks great, its smooth as glass and no wear or cracks.<br /><br />I noticed a plate that had 4 bolts and some wording that said set points @ 0.20, so in all my brilliance I determined the points were under the plate.<br /><br />I took it off and everything in there looks brand new. I didnt adjust anything because I am not sure how or if I need too. Heck I may put some gas in her and she will hum like a top.<br /><br />I took the plugs out and sprayed a little WD40 (at a friends recommendation) to make sure the pistons were loose and they are and there is good compression coming from both holes.<br /><br />What manual would I get for this thing. I know that J.B.Cornwell said this was a 1959 model. I have looked at other models and it dosent look like its that old however, Im sure J.B. knows what he talking about. I just want to get the right manual. Like I said it may and probably will run as it is.<br />Thanks for your info
petryshyn
Hi spur:<br />Sometimes removing this flywheel can be a tough job. Since its potmetal, the threads often strip while using a puller if you're not carefull.<br />If the unit runs well, you might want to rethink pulling the flywheel (unless you intend to restore her)<br /><br />Just a thought...... :)
Spur
estion (for now) You mentioned me replacing the "water pump empeller", This is something I want to do, how hard is it and where is it located. If Im not mistaken, this is what pushes the water through the motor so it doesent burn it up.
Spur
dang, I butchered that last post....<br /><br />It should read "one more question (for now)...."
alcan
Spur, you can buy a Clymer or Seloc manual or as J.B. suggested,check one out at the libaray.Your motor is a 1959 no doubt.It probably will start. If you want it to be reliable, read the book and do the maintaince. Good luck.
Spur
Alcan,<br />Thank you very much for your advice. I will locate a manual from somewhere. I wouldnt mind buying one just gotta find the right one. Thanks again for the confirmation and information.
Bear
Spur
Bear you are the man! Thanks bro.<br /><br />I just found this site yesterday and all you guys are awesome. Great info for a rookie.<br /><br />I just wanna find the ducks and hogs, but to do it I have to know the motor stuff
Spur
I have another question, If I change the water pump (impelor)what ever its called. Do I have to take the power head off on this model? If not how do I tackle this job. Thanks
Pursuit2150
no, you drop the lower unit.To remove the impeller, which is housed in the water pump.
