Re: Help Please Johnson Seahorse 5.5
Hi Spur.<br />Those 5.5hps are great little motors. I used one for years until I got stupid and sold it. I would pull the fly wheel,check the coils for splits and cracks, clean the points. Then take carb apart and clean it. I'd also install a new water pump empeller, pull prop off, check for fishin line, greese prop shaft. Now these older rigs use a presure fuel system. So you need to pay special atten. to the tank, hose and connector. All gaskets, o-rings need to be in good shape. Like J.B.Cornwell said 24:1 on the mix. Don't short the oil and it might run for ever, maybe longer. If you have problems with the tank,repair it. A good tank and connector is worth more than the motors they run (in my area).Have fun hunting.
