waters2415
- Jun 25, 2014
- 1
I have a 93 Skeeter SS140 with a Evinrude 150 xp. I'm running a 24 pitch raker. I'm running 56-58 GPS speed. Any suggestions or mods to engine to get speed up in the 60s
If the engine does not have enough hp a nose cone will actually slow you down as the overtrimming can make the nosecone pull transom deeper in water.Boat that run the upper 60-70's with stock units will benefit from one..You speed is about correct for all purpose use set-upJack it up and put a racing style lower nose cone on it with a low water pick up.
The Starfire was always a fast hull....
