Help please, 1995 Evinrude 130hp wont start
Jsioch
My 1995 evinrude 130hp won't start. After sitting for 2yrs it cranks over slowly even with a new battery.Could a bad impeller on the water pump cause it to do this or do I have bigger problems?
Honorary Supreme Mariner
It is not the impeller.--Remove starter and inspect starter / load test battery / inspect battery cables.----Starter may just need cleaning and new brushes.--Easy to do that part.--A motor that cranks over slowly will not have spark.---Therefor it will not start.---Where carburetors empty during storage or left with fuel in them?
Jsioch
Thank you for responding I replaced the starter about 4yrs ago I cleaned and inspected all connections and cables I had the battery with a quick start charger hooked up to it. I'll have the battery tested and check for spark I treated the fuel and ran itbefore I put it in storage
oldboat1
Dispose of fuel -- Get a couple of gallons of fresh fuel for testing. Unless carbs were stored dry, disassemble, clean, and rebuild them. Replace impeller. Drain and replace l.u. oil. Load test and fully charge or replace battery.
remove, clean/regap or replace plugs; check compression and spark while plugs are out. Install plugs. Test in a tank or deep barrel, water running.
jakedaawg
Do not add new fuel to old. 3 gal new fuel + 3 gal old fuel = 6 gal bad fuel. Just my humble opinion.
Never add new fuel to any amount of suspect fuel. Just a waste of money.
