labxxxbrat
Thread starter- Joined
- Jun 14, 2008
- 4
Boat has been behaving well except for misc. electrical issues (salt water). Boat runs great, 19.x ft center console sportsman with 120 hp, 2 stroke outboard. Had a new magnito replaced a few months back and everything has been running smooth. Coming back from the Gulf this evening and scooting around 4200 rpm, an alarm sounds. I look at everything and it appears fine however, the temperature begins to rise as does the battery charging meter. The charge meter is still in the green but is slightly above 14vdc. I understand that 120% charge rate (13.8 vdc) is normal and a little higher is tolerable. Now, the temp guage is starting to climb higher. I examine the water coming out of the engine (cooling); excellent. I pull over, turn off the engine and check the cover for excessive heat. Within tolerance/fine. Tilt the engine up, water comes out, tilt it back down, start the engine and everything is fine. Scoot for 10 minutes at 4000 rpm and the engine bogs down again. At this point, I disconnected the alarm and simply monitored the temp/charge meters. Temp normal but charge a little over 14 vdc. Pull over, stop engine, tilt engine up/down, restart. No problems, behavior is normal but now it bogs down if I go higher than 2800 rpm or so. The engine feels like it is misfiring and is awfully sluggish. I made it home but my boat is not happy. There were a couple of times that I could scoot around under 5000 rpm and have no problems and then there were times that I couldn't get it above 3000 rpm without it really shaking. Tilting the engine up/down intermittantly kept the voltage level within check... dropped down below 12v (still green) and slowly raised up to 13 and then quickly went up to 14+ vdc.
I am not sure if these are related problems as I always seem to have wiring issues with the salt water.
Any help would be greatly appreciated. The engine has been a great engine. Think it is a 1998 engine. Also, no smoke coming from the engine (except when I cold start it ... normal).
