Skippy the skipper
Thread starter- Joined
- Oct 29, 2007
- 20
Hi, I have a 1985 140HP Johnson that will die after throttle is cut from running at WOT. It doesn't matter if I lower the throttle slow or quick, it will still die after I slow down just a little, not at wide open. I can run for as long as I give her full throttle, pull back on the gas and instatly stops running. Throttling up seems ok but the boat doesn't seem to perform all that well either, slow to get on plane. I have rebuilt the carbs( were dirty), tested the VRO fuel pump (13PSI at WOT), fuel bulb is good after a run, checked the spark and done a link and sync. After a run I have pulled the spark plugs out and they show no signs of water (but have fuel on them) and my compression is around 120 more or less on all cyl. BTW I put a pump in the lower unit and changed the T-stats before I ran this as it had been sitting up for a year +, temperature looks good with my handy temp gun. I am normally a pretty good mechanical kinda guy but this is driving me CRAZY! HELPPPPP!
P.S. once she dies I have to choke hard to start her, will not just fire up!
