2004 searay
- Jun 30, 2023
- 70
hi, i have a searay with a 5.7 MPI engine, bravo drive, serial # ow027371, this has the fuel pump under the port side engine mount. i had a problem last season with no power and diagnosed as low fuel pressure, 28psi and 32 with reg unplugged. over the winter i replaced both pumps with OEM units and the fuel regulator and filter screen down below. now i fire it up and i am only getting 30PSI and 38 with regulator unplugged. . i checked the fuel supply line and thats ok, ran a seperate tank of fuel to the input line, tested the power to the low pressure pump, and the high pressure pump i can hear run so i know the power is getting to that one. i am so sick with this issue, i spent a lot of money on OEM parts and to still have this problem is so discouraging. i also tried 2 different fuel pressure testers, both give the same info.
