Help needed w/ MinnKota Allterrain mount
biglenr
Greetings all -
I made a yard sale purchase of a 55lb thrust minnkota all terrain motor. Only problem.. The previous owner took it all apart in an attempt to make it a transom mount instead of a bow mount. Still, the price was good enough that it was worth my time to put it together. I hope.
The all-terrain is a bow mount, with a pull handle. See attacment for part diagram
Google Image Result for http://www.northlandmarine.com/images/MinnKotaAllTerrainDia.jpg
I found that all the parts are present. And I've figured out where everything goes. My only issue... there is a spring (64) that needs to go between two parts (62 & 63) and be held together by two halves of a metal frame of the mount (60 & 61). The only way that can happen is if the spring is compressed about 30%.
And I can not do this by hand. No idea how to get that spring compressed and keep it that way. Note: The ends of the spring need to fit pretty precisely, so I can't have anything holding the ends.
I tried stepping on the spring to compress it, and using cable ties to hold it in place, but when the spring uncompressed, it broke the cable ties.
I really don't know what to do with this, would welcome suggestions.
Thanks.
