flyingscott
- Apr 8, 2014
- 8,306
Did you adjust the screw by your pinky to get to the 15 deg timing.
picture is incorrect as to how it actually looks right now. Also I found that the float should be set to 35/64's to 37/64's. I have it set to level. As in this picture -
and take the spark plugs out. YOU THEN advance the throttle all the way until the timer base hits the screw under the flywheel with the rubber stop. Then put your timing light on it and time it and if it needs to be adjusted you move the bolt with the rubber tip on it. .
Click on the link in post #8not following here..if the plugs are out how is he going to test the timing with a timing light? Are you thinking of using a remote starter to rotate the engine(via starter) without the plugs in (so it CANT start, whilst at max timing)....that's a good idea...safe way to set max timing....
question with the wheel spinning (via starter) slower than actually running would that affect max advance by much?
should he ground the plugs or ground the secondary coil wires if he removes the plugs completely?
THAT IS THE WRONG SCREW TO SET THE TIMING WITH!!!!!!! I have told you that 3 times. That screw that you set the timing with is the idle screw if you manage to get it running it is going to idle WAY TO HIGH. The 19 deg timing is your HIGH SPEED TIMING. To set that timing on your motor you need to disconnect the shift cable and take the spark plugs out. YOU THEN advance the throttle all the way until the timer base hits the screw under the flywheel with the rubber stop. Then put your timing light on it and time it and if it needs to be adjusted you move the bolt with the rubber tip on it. And back that idle screw back down NOW.
which translates to this -
So from the top of my float to the carb should be about 9/16th of an inch? The only thing is my float is about 5/8's of a inch thick which means is would not be level and it would be slanted away from the post holding it in? Unless this is the wrong setting for my float. And if it is correct then I have my floats set incorrectly. :-( I found it on www.youtube.com I had it at a local shop for about 3 weeks and allegedly they worked on it and were unable to get it as far as we did. But still charged me $330 to "work" on it. Which I totally get that they did do something to it.
flyingscott,
? If not I will wait for my manual which is supposed to be here tomorrow. Previously when I turned the key on it made the oil alarm go off. Now it does not. I tried jiggling the key and the handle on the throttle if the neutral switch was loose or messed up, but the alarm didnt sound. Maybe cause of the new VRO Fuel pump? I can not think of what else to do guys! Anyone got a shotgun to shoot this dam thing. Its been laid up for 2 years. Id say its a f'n paperweight but to big for that.
