upwindskipper
Thread starter- Joined
- Jun 26, 2010
- 13
Motor will idle all day with temps in the high 120's on the thermostat housing. As soon as I put it in gear and advance throttle to 2000 PRM's, temp starts climbing until it sets off the alarm at 180 degrees. Here's what I have done so far: new thermostat, Mercury service guy rebuilt the water pump with new impellor and base plate, I have run a salt-away cycle, flushed with vinegar, flushed with water down from the T-stat hole and up from the water tube. Signal stream cools off at higher RPM's (90 - 100 degrees) then warms up at idle to 120 degrees.
Am at my wits end, summer almost over and I have yet to go boating. Will appreciate any and all thoughts.
