Help needed: 1st trolling motor
JackDeere
I need to install a bow mounted trolling motor and have no prior experience. Boat is a 17' aluminum utility. It's a fairly light boat w 40hp OB, so battery weight is a consideration. Bass is the target on small, shallow, very weedy (pads and hydrilla, but little grass) coastal lakes. Soft bottoms, not much wood to worry about. But need to be able to chop through heavy weed cover. There is some, but not a whole bunch of room forward for large foot controls unless the seat is removed. Lakes are typically 5 to 15 feet deep, so submerged contours (to follow) are minimal. Casting, not trolling.
Motorguide or Minn Kota?
Thrust?
Favorite mount and accessories?
cable steer or electric?
I'm starting my 6-year old out bass fishing and really appreciate your help. Thanks!
John (Jack) Deere
17' Gregor Osprey
40hp Nissan
6hp Nissan kicker
HONKER1
Re: Help needed: 1st trolling motor
For my money I would go with the Minn Kota PowerDrive V2 with 55lb thrust. This will keep you with a 12 volt battery and you can elect to add on later. With the wind and waves that I am always fighting, the AutoPilot just doesn't seem to work out for me, but the CoPilot and foot control was definately worth it.
I use the MKA-21 mounting bracket. This is ideal for me, because I have a multi-use boat. Sometimes to ski, sometimes to fish. Good to remove motor when not needed.
JackDeere
This is the very motor I had been considering. Do you get reasonable responsiveness out of the copilot? Realizing that wind, speed, boat weight, hull design and weeds are major variables, about how long do you get out of a fresh group 27 battery? A full day most of the time?
Really appreciate the help, sir.
Jack
John_S
If you are looking at wireless, check out Motorguide as well. I have been using one all season. It comes standard with a removable mount, and does not rattle and make noise like the non-cam lock adapters for MK. The cam-lock mount is rather pricy. While I have a 45lb on 14' alum (w/40hp Nissan :) ) would recommend 55lb for you.
Bass fisherman prefer the wire cable type control. It gives them better feedback and can be used with less visual inspection of motor direction. The wireless or elec footpedal make for easier store and deploy. I like the wireless with keyfob. The foot pedal is stored away and both front and back fisherman use their own keyfob. When the front guy is dealing with a large fish, snag, or other distraction, the guy in the back can take over.
I have a spare 3-blade machette prop that is ok for weeds, but the ones I generally encounter do not sound as tough as yours. There are other after-market devices to help.
http://joefish.homestead.com/TMTDmount.html
Silvertip
Honorary Supreme Mariner
I have a MinnKota PowerDrive V2 on my pontoon and it tugs it around just fine. It will run all day on a high capacity group 27 deep cycle battery. An just so you know, just because the battery is a group 27 does not make it a high capacity. Check the label. Reserve minutes at 20 amp load is the key.
JackDeere
Can someone explain this?
How many reserve minutes?
