Help Needed!!! - 1961 Evinrude 18Hp outboard - Help needed!!!
Liamfjortoft
I have an old 1961 18hp evinrude outboard 15034 that has been sitting in a garage for about 5-6 years. I have done a bit of work on it such as changing the spark plugs, stripped and cleaned the carburetor etc. After cleaning the contacts on the starter the engine fires up and continues to fire up first time. But, after around 40-60 seconds of running the revs increase and the engine cuts out. I am not 100% sure if this is an engine problem or my lack of knowledge on the general operation of the motor in terms of carburetor adjustment screws for low and high speed and tiller controls. Any advice is greatly appreciated thanks.
Honorary Supreme Mariner
Revs up and stops-----That indicates to me that the carburetor is running empty.-----So check by operating the manual pump to see if motor keeps running.---------Check fuel pump and your gas lines , including the pick-up tube inside the tank.--------Perhaps replace o-rings in fuel connecters.---------If you have an original OMC tank do both small pins on the tank stick out the same amount ?
Liamfjortoft
Thanks Racerone, I will have a look tommorow to see if the engine will run while operating the manual pump. The fuel tank is abit old and could be a possible origin for the problem although when originally pumping fuel through it seems to work just fine. I will try your suggestions out and update after. Thanks again.
F_R
I agree, it is running till the gas in the carburetor is consumed. OR the gas is not being pumped into the carb as fast as it is being drawn out. Could be faulty fuel pump or could be a leak. ANY leaks anywhere between the fuel pump and the level of the gas in the tank will cause the problem because the pump will draw air through the leak instead of lifting the heavier gas.
Liamfjortoft
so I've managed to get the engine running for prolonged periods now by operating the fuel pump. I replaced the seals on the fuel pump and this seems to have made no difference. I will now have a look at the fuel lines and tank to spot any leaks.
Can anyone confirm that the fuel mixture for this engine is 24:1 and also would anyone know what gear oil is to be used for the prop shaft gearbox.
thanks, Liam
Liamfjortoft
thank you very much, tonight I changed the gear oil with some yamalube SAE90 gear oil. was very surprised at how good the old oil was considering the time it had been sitting, only slightly gone brown. I have ordered a new male fuel connector and will be installing a new fuel hose up from the tank to the engine asap. hopefully this fixes the problem with the fuel.
