marinemike366
Thread starter- Joined
- Nov 23, 2009
- 8
hi all, hope you can help me with this problem. i have a 115hp evinrude motor and i took off the bottom end to get serviced. gears are all OK, my friend changed the oil, and put new filters on.
now when i'm trying to re-assemble the motor, i cant seem to get it lined up.
i can change the gears manually on the bottom end no problem, however when i try to line up to the top end, will not go into reverse at all.
i know that rod with the curve has to be attached properly to the link inside the top end of the motor, but i cant seem to line up at all.
when i pull that shifter rod up, it that reverse or forward?
if anyone has any suggestions to help me with any tricks i would really appreciate it.
