Help! Need info on 69 Johnson 115 outboard
Basdas
Hello newbie here and as green as can be. Wife and I want to get a boat. Live in Southern California am a mechanic old school as in non computer vehicles on down. My friend has a boat owned it its entire life and looks real good. It is a Glasspar 17sp 3053. The motor is 115esl69s serial j3046174. I know two strokes might be a little limited as where they can be run.
Question: Are parts still available for this old Johnson? Don't want to buy a boat with a motor I can't get parts for because eventually all motors will need parts and maintenance. In the advent parts are available where would I look. Any help Would be appreciated.
Thanks
Basdas
jimmbo
Some parts are NLA, but a lot still are. The oil for the gear case is critical on these engines. Must be kept clean and water free. A 'Type C' oil is speced. You can't go wrong by using BRP Premium Blend(OMC/BRP new name for their Type C oil). Other brands of Type C may or may not be usable, depending whether or not they say they are usable in Electric Shift cases
Basdas
Thanks for part info. Is this model reliable? Local shop said these were not the best. Look for something else.
F_R
Honorary Supreme Mariner
You can hear any opinions you want to hear. Actually, those motors were state of the art in 1969. But in hindsight, you could do better if you move up a few years. At least newer enough to get the much better Mag CD ignition system.
Basdas
Can you put the mag cd ignition on the earlier units? What year did the mag cd started with Johnson?
jimmbo
MagFlash ignition was first introduced on the 50 and 65hp loopers in 72. In 73 it was also used on the V4s. It can be retro fitted? I really don't know.
Edit: Correction: as pointed out by Racer below. the MagFlash was actually introduced on the 71 50hp, not the 72
Magflash was intruduced in 1971 on the 50 hp.-----Magflash would be difficult to install on a 1969 model 115 hp.
