MikeL77
- Apr 24, 2014
- 6
I am looking at purchasing a 1995 3508 Myacht houseboat. There are several perforation holes in the outside of the aluminum pontoon directly below where the toilet was. The holes are below the waterline. There is only a porta potty now. Is the black water holding tank inside the pontoon itself? Chemicals eating through the aluminum pontoon from the inside out? If this is true, CAN THE HOLDING TANK BE ACCESSED FROM INSIDE the houseboat, OR?
We are looking at welding an aluminum sheet of metal over the area where the holes are found. Will this suffice, or will more extensive repairs be required like replacing that section of the pontoon which seems to put the kabash on the purchase.
Thanks!
Thanks!
