Looks like your 950 is a 1967 model.
I have found the below-listed site to be really good for looking-up parts, very clear diagrams and parts listings, plus wherever available, they post actual pictures of the parts:
Mod EDIT: web link removed
Just remove the spaces after you copy & paste into the address bar. iBoats parses some competitors' web addresses.
Mod EDIT: please dont post links to websites that are competitiors of iboats, our gracious FREE host.
Once you know what part numbers you need, check the iBoats parts section as they do have some quite good deals on the various parts that they do carry. Other things you may find on eBay, etc. Once you know parts numbers, it's so easy to search around. Some parts are NLA and eBay may be one of the few resources available.
BTW your "SS" model should have the early form of Merc's C-D electronic ignition, which on this model was fired by a "breakerless" distributor with a replaceable trigger assy. So, if you have spark issues, it'll be quite easy to troubleshoot.
One good tip on that system is that the red terminal on the switchbox (Stbd) side has power on it all the time. The white terminal next to the red (same side) is switched, so in order to get spark, both red and white terminals must have +12VDC on them to ground, with the key in the "ON" position.
If you have spark, the best things to do to resurrect your engine would be to renew the impeller; replace fuel pump diaphragms; and clean the carbs. Plus anything else you find such as hoses & wires which are deteriorated.
The 90-cubic-inch Tower of Power is an excellent runner, with a smooth idle, and will push a smaller boat very nicely.
Congrats on your find, that's a great deal for a classic Merc on a classic boat!
HTH..........ed
