Help! My aluminum boat leaks!
taotao61
Hello all.
For some time now I have experienced dreadful leaks in my 14 foot aluminum, I have read good things about the product "GLUVIT". So I went out and bought two quarts just in case I may need more than one. I took the boat off the trailer, flipped it and placed it in the garage for this sealing job.
In the past I used 3M 5200 for a temporary fix, but it soon became an endless saga of very wet sneakers out on the water:eek:! So my big question is before I sand down the hull, should I also remove the 5200 from all the seams and rivets that I covered in the past? Or just go over it entirely?
Thanks, Tao
Bob_VT
Re: Help! My aluminum boat leaks!
Do the gluvit from the inside......
People have used it on the outside of the hull as a barrier coat but the inside is best.
Tighten the rivets first.......
The 5200 failed??
Welcome to iboats!!!
CheapboatKev
Yes..Welcome to Tin City..lol
Bob is correctamundus..
Gluvit on the inside..
Tighten rivets first..BUCK EM..BUCK EM ALL...lol..
Get a buddy to hold a 5lb sledge on the inside rivet..and WHACK the out side rivet with a good ball peen hammer...
tmcalavy
And one or both of you may need earplugs...unless you like a ringing in your ears for several hours.
