HELP!!! Motorguide Pro 46lb trolling motor power issue
Lets Fish
Hi, I need some help. I went to the lake last nite, and my trolling motor would not work on any speed. I checked the power from the battery thru the plug in and it was good. Any suggestions???
Motor is appr 18 months old and used maybe 30 times, last used 3 wks ago with no issues.
Thanks in advance for any help you can provide.
Re: HELP!!! Motorguide Pro 46lb trolling motor power issue
How did you check for power on the motor side of the receptacle. Although you have power at the receptacle, it may not be getting through the plug to the motor. The power cable between the plug and the motor may have been pinched and cut or broken due to flexing. Check it carefully
