HELP! Mid '80s Sea Ray Seville fuel tank openings question
Panoguy
Ugg - probably a silly question, but I just can't remember, after 3 years of disassembly!
The 30 gallon under-deck fuel tank that came with my 1984 19-Ft. Sea Ray Seville, has (obviously) a fuel fill opening (on the starboard side), then right next to that is a smaller opening, then off to the port side (farther away from the fill & other opening) is another opening similar to the first small opening.
So, we have 2 openings grouped together (fuel fill & ???), then another opening off to the port side of the tank.
OK - my question... which one is the vent, and which one is the supply to the engine??
Panoguy
(crickets)... well, I'm going to guess that the fuel supply is the small spigot next to the fill, and the vent is the one by itself, toward the port side. Guess we'll see.
kcassells
{grasshoppers** Pic would help. But I would gander to say you are correct. I think the vent is 5/8" and the fuel to motor is 3/8". Fill to tank 1.5"
I tried to google that particular tank but there quite a few design variations. Snap a pic and paste it.
Typically fuel is largest, vent next and supply next in sizes.
