wallyevs012
- Jul 4, 2003
- 46
Hi Folks,<br /> I just mounted a new Motor Guide 54 lb thrust with 50" shaft and breakaway mount on my new Lund boat. I thought everything about position was good and when done found out the motor head just grazes the bow light which is screwed down in the bow. I can lift it over and use it but I really have to be careful. If I move it (which I assume I'll have to do), is there anyway to cover up the holes? The plywood deck seems to be about 1 1/2" thick in that area. Any help or suggestions appreciated. Thank you, Wally
