Help me pick the right impeller.
Fordiesel69
Guy,
Right about now I would like to start getting the parts for my lower unit. It is a 1990 Bayliner with a Merc Alpha 1. I have the serial if you need it. I am kinda dumb when it comes to knowing what I need, but I need everything to install a new impeller. I want it all fresh, so I want the housings as well. Can someone give me a link?
Does this all come in one full kit or do I need to know what to order seperatly.
Thanks.
achris
More fish than mountain goat
Re: Help me pick the right impeller.
Ayuh.... That'll be the one... Just be aware that it's a 'multi-fit' kit.... You won't use all the parts in the kit... So don't go looking for something you've missed just because you've got bits left over... :D:D:D
Chris......
Fordiesel69
Great!
BTW, any downside to using aftermarket sierra parts over genuine mercruiser parts? As being just an impeller, I'm sure it makes no diffference, just checking.
JustJason
Aftermarket VS OEM can make a big difference, especially if your talking rubber parts.
If your putting an impellar in just to say you did it and your selling the boat, save a buck, go aftermarket.
If your keeping and running this boat, go OEM.
BTW~ To each their own but when ever I do pumps I just order the whole pump kit with baseplate, gaskets, and cover, I never just do the impellar. I've never had to re-do one that I did because of issues afterwards.... But have had many of folks re-do their own because they have air leaks.
Fordiesel69
Well, I put it off like an idiot and will be doing it this month so hopfully I will be ready for may 1st.
Can anyone point my to an OEM one.
