Help me..... need info on this bellhousing.
Josh P
I have this bell housing.. actually 2 of them but they are the same. I do know they are made by mercruiser, but i cannot find ANY info on them.. I am looking for oil coolers and gaskets for them.. I have coolers but are corroded pretty bad. This isnt my bell housing but mine is identical
I have emailed a place that makes a replica but is diffent im awaiting a response from them..
Just hoping some one knows a model number or something.... thanks Josh
Don S
Re: Help me..... need info on this bellhousing.
Can you give us a clue as to what engine, what drive, what year, anything ??????
Josh P
The transmissions are borg warner velvet drives the engines are 509 Big Block Chevy's go into a catamaran hull with surface drives not sure on the brand of drives..not quite sure on year.. i wanna guess 80's or early 90s..
achris
More fish than mountain goat
The closest I see is a flywheel housing from a Mercruiser 390MIE (uses a GM 482 block), circa 1969-70. The housing number is -47554... But it's No Longer Available from Merc....
Good luck,
Chris.....
Josh P
ya i just found some more info on it, they were also used in 84-86 as well.. i am still waiting for a response from the company that sells the kit above.. i really just need the tank gasket which i found and a cooler, the covers are seperate. so i think ill be ok. thanks
