help me mate my evi 25 with my johnson 25 PLEASE....
riverhippie
Hers my problem i just picked up a 1982 evinrude m# e25rcnb minus the lower unit. also have a 1972 johnson 25 m# 25r72r. i tried to swap the lowers out but found out that the shaft is smaller on my johnson both motors are short shaft. i talked a buddy of mine that had sold the motor to someone else witch is who i got it form. my friend says he hhas a spare drive shaft from the evi. so is there any way i can swap out some parts and put together my own lower unit? PLEASE HELP ME GET BACK ON THE WATER AND OFF THE DAMN COMPUTER. thanks for all and any help u can give.
mark1961
Ensign
Re: help me mate my evi 25 with my johnson 25 PLEASE....
You are better off keeping everything in one thread for reference and not starting three on basically the same topic....gets confusing.
From what i can tell the lower units did not become directly interchangeable until the 1979 model year.....it will take some stuffing around to get the one you have to fit if its even possible.....after you have confirmed that the two halves will mate correctly my initial thought would be to take the two driveshafts to a machine shop and see if they can modify both so you end up with one shaft to suit your needs.....short of sourcing another lower unit that might be the cheapest way out.
