Help Me Live Again!!!!
steelieone
I have a chrysler 60hp magna11 motor it was swamped under water took someones advice(frank)was more than helpful,now it seems i am not getting fuel to the lower carb i pulled the hoses and cleaned the bowls and sprayed carb cleaner into both but gas just seems to pour out of the top carb when i prime it with the gas tank primer but not the lower carb it turns over very well but just not continously running does anyone have any suggestions.
MN_Jack76
Re: Help Me Live Again!!!!
If I had any brains about boat engines I wouldn't be on these posts - lol. But if your carb is anything like a Holly - i would check to see if the needle valve on the float is stuck. also is there a float adjustment?
Haywood123
Can you get any gas into the lower carb? What if you disconnect the hose to the top one and plug it (philips screw driver and a hose clamp will do it) then pump the bulb?
