Help Me Find Out What The Heck This Is!!!!!
randyt
I bought this Evinrude trolling motor and was told it was a 12/24 volt 56lb thrust... when I received it.. I am kinda doubting that is what I have here. If you can tell me what I have I would appreciate it.. It is an Evinrude (that much I can tell lol) model number is EB52C and the serial number on it is E0001059. Any help I can get will be greatly appreciated.
wcsparky05
Re: Help Me Find Out What The Heck This Is!!!!!
you need to purchase a multi-meter. invaluable. priceless. its a must if you want to troubleshoot electrical. i'm an electrician and without my multimeter i wouldn't have figured out why my amplifier wouldn't turn on!!!!
it will save you $$$$ in the long haul. or just pay the man.. he'll bent you over, though! solid multimeter at sears for $19.99 ac/dc/resistance (ohms) if you own a boat, it's a must have!!! sometimes start-up voltage is necessary, so if you have too many devices piggy-backed to your ground (black on the battery) you will not have adaquite voltage for some of your applications. sort of like a motor that requires more startup voltage than to run a motor. you will get the necessary voltage if you run a hot to the battery and a ground the same way with no interruptions. always use an in-line fuse to make sure not to damage your equipment or start a fire or worse, explosion. :)
randyt
Thanks for the replies, I did call Crowley and got the information I was looking for.. lol for the record.. it is a 1977 Evinrude.. but still do not know the thrust of it. But we are at least on the right track now.. Thanks again for your help.
