Help! looking at a merc tommorow...
gofast26
Hey guys, i need your help. Im looking at a, what i believe to be 1977 merc outboard. Its on a decent boat but is missing the control box with the key/choke/throttle. I would really love to try and fire the boat up tommorow. Is there any way of turning it over without that box? If anybody has any advice on what i should do to go about determining if this motor is worth it, could you please help me out. I appreciate the help.
Alex
Its a 65hp motor, for some reason i cant post a reply in a thread sorry guys.
Silvertip
Re: Help! looking at a merc tommorow...
If you know how to jump a solenoid you can start the engine. But you need to disconnect the fuel line to stop it. You will also need to run the throttle and choke by hand.
Jeff_G
You didn't say what HP. Most of the larger inline motors had battery operated ignition, you can't just jump the solenoid to start them.
If the engine doesn't have a distributor then yes you can jump the solenoid to start it.
Use a starter switch from an auto supply and hook it to the yellow/red wire small terminal on the solenoid and the other to the large battery terminal on the solenoid. There will be a manual choke.
