Help leaking water out of 305
Bushidomma
Hey I'm new to boating and I bought a 1986 invader cuddy with a 305. It runs great, but my problem is when I hook it to the hose and let it run after I shut it off I notice a little water dripping from some sort of plug that looks like a T it appears to be brass. It is located at the front starboard side of my engine. it has the mercruiser 305 I haven't had it in the water yet but was planning On it this weekend. All help is appreciated. Thanks
Grub54891
Re: Help leaking water out of 305
It's probbally a block drain petcock,take it out and clean it up,they get rust flakes in them and sometimes leak a bit.
Bushidomma
Thank you for the quick reply I will try that tomorrow when I get home. Do I need to put some kind of sealant or thread locker of some sort on when I put it back in? Thanks again
Lyle29464
A sealer will help in several ways. 1 is seal. 2 it will make sure you can always get it out. 3 stop reaction between 2 metals.
Bushidomma
Thank you as well is there a brand type you recommend?
Lyle29464
I put permatex on almost every bolt, etc. I use in a engine.
Grub54891
Geeze it's just a petcock,if it came to my shop with sealant on it it would get replaced.All you have to do is clean it up,if it still leaks then replace.I've seen plenty of boat engines with permatex,silicone sealant's ect.....If it leak's with new gaskets it needs to be replaced,why take the risk of something happening out on the water.
Fishermark
Any pipe thread should get a sealant for lubrication if nothing else. I too use Permatex thread sealant:
DisplayImage.asp
Lyle29464
Yup good stuff. I have always been in a saltwater area. Really silly to pull a motor so you can drill something out because some guy was trying to "beat the clock"
