Help intermittent power loss on new 25hp motor
dnewcomb
Just bought new boat last week with a new out of the box 25hp johnson from year 2000. Ran like top for the first 5 gallons then bogged down only about 1/2 power. Will run @ about 3/4 if I push choke in and out but not if i hold it in. Sputters rough at lower speeds as well but always starts well.<br /><br />Sqeezing bulb no help, messed with tank venting also no help. Put new gas in the tank and no help.<br />Put in new plugs no help.Put on a new gas tank ran great for 30 minutes. Tipped the motor up and fished for a while and problem back.<br /><br />At this point took to the shop about 1hr drive away and ran fine when there. They took carb apart and gave me a new external fuel line, checked the fuel filter and found no probs. I then took it out to the lake and ran like a top for 40 minutes with no problems so I loaded up and went up north to go fishing. Dumped it in water and problem back immediately. Took it back to the shop and they have it now and claim running fine and can't find anything wrong with it. They even took it on the lake to run under load and no probs.<br /><br />3 questions first any suggestions as to what might be wrong with this thing.<br /><br />Second question. Reading this board I have seen similar problems that people struggled with and spent a lot of money on to no avail. What are my rights? I mean I bought a brand new boat for a reason so I didn't have to mess with this stuff. Its already taken up 4 vacation days not to mention I'm missing this weekend fishing. If I get it back this time and it does it again can I demand a different motor especially since they can'tdetermine whats wrong with this one? This on is under warranty<br /><br />third question. when running rough I pulled off spark plug wires. If I pulled top plug off would run rougher but still run. If pulled bottom off engine would die. should they behave the same?
JB
Re: Help intermittent power loss on new 25hp motor
Howdy, DNewcomb.<br /><br />Your top cylinder is not making full power at all times. <br /><br />The results of adding a little choke suggests a loose reed valve that is moving around, or a leaky gasket under the reed plate.<br /><br />Another possibility is a failing coil in the ignition system.<br /><br />Good luck. :)
