Broke my key off in the ignition, so decided to install new ignition. I've wired it exactly as the diagram on the box and found on the internet.
red/violet wire to = B
yellow/red to = S
violet/white to = C
black/yellow to = M (raised)
black to = M
I only had 5 wires the ones listed above, there is a connection for another wire labled "A". I don't have a wire to go to this connection?
I wired it as listed above and nothing? I don't hear anything.
My old switch was wired slightly different, it had a push button under the ignition
The push button had the violet/white wire connected to it, then a wire from the push button to the ignition. I was told the push button was used for the "choke solonoid. I wouldn't need it with this new switch because the chock would engage when you push the new ignition switch in.
Help would be appriciated
yellow/red to = S
violet/white to = C
black to = M
