dawg gone bad
Thread starter- Joined
- Jul 6, 2009
- 3
I have a mercruiser 170 with a wagner alternator conversion kit. My boat was running fine so far all season. Then I was stupid. I tried to help someone by giving them a jump start my boat shut down and would not restart. The starter would crank but the boat would not fire. I replaced the coil and the boat started. While underway after about 15 - 20 minutes she shut down again. The next step was to replace the points, condenser, rotor and cap. Still no luck. Have tested for spark and it appears there is none (am I testing it the right way? not sure.) There is power to the coil and out both sides 12 volts. What should I check next?
