Help i'm rusting away
Bryce2004
I have a 2007 Mariah 3.0 Merc. the boat is stored on a trailer and not left in the water at all. My engine is rusting at a rapid pace is their anything I can do to help prevent this issue????
Re: Help i'm rusting away
Ayuh,... Wire brush it, scrape it off, 'n keep it Painted helps...
Boatin' in Saltwater are ya,..??
jimbo_jwc
Ship Happens
Don't know what to use but I'm going to try LPS2 maybe 3 .1987 3.0 mercruiser I'm first to leave out all winter since new . Kept running elect. heater every time damp/wet out motor starting to rust a little .
arks
LilRedNeckGirl
heat & moisture = rust. try putting in a bildge dryer/ chemical water absorber. then if you winterize properly, there is no need for heat. That heat constantly vaporizes the water, then it recondences on the cold block. NIX the heater !!!!
