Help identifying a part and its purpose.
Rodbuilder72
Hi new to boating and 2 stroke outboards. I have a 1990 evinrude 150 2 stroke. I rebuilt the carbs and its running way better. I'd like to know what the part where all the fuel lines go into, with the orange dial that moves, and what it does. Been looking online for awhile to figure it out, with no results. Thanks in advance.
flyingscott
Which one The bigger one is your VRO pump the smaller one with the red lever is the primer for cold starting.
flyingscott
Primer for cold starting it replaces the choke butterflies on the carb. When you push the key in to start that will activate and push fuel into the motor via the little hoses coming out of it. When the lever is the way it is now it works electrically when you turn the lever it can be used manually by pumping the primer ball on the fuel hose a coupe of times. You only want to run the motor with the lever the way it is now the other way will flood the motor.
jakedaawg
You can test whether or not it's working. Push key in when it in the run or start position. You should hear a click. If not, check for twelve volts.at the solenoid when key is depressed.while in the run or start.position.
Rodbuilder72
Thanks a lot! That's exactly what I was looking for. It is working, because I heard the clicking. I thought it was something along that line. I put the dial in that position after I fixed the carbs, it just ran better there. When I got the boat it was always in the 3:00 position. I'm also guessing that is part of the reason why it was a bastard to start cold, and load up with fuel so bad it would run right out the Front of all 3 carbs, and constantly foul plugs. It starts great cold now. My only issue is it idles a bit low.
