help identify
nellie1
i have a 80hp 800 4 cylinder merc serial 5004637 can anyone tell me year. and prop shaft number.the engine runs good but the boat only goes like five miles an hour wide open. i spun propellar and its bent.
nellie1
Bent prop shaft
1978 80 hp800. Starts and runs well but will not go fast. Prop shaft bent What could cause lack of power to propellar
no, it would make it shake and vibrate, ultimately taking out the bearings which could cause lack of power.
merc850
The rubber insert could be slipping at around 2000rpm and up. Maybe the pitch is too high; is this a new to you rig?
fhhuber
Will not go fast as in engine won't spin up RPM or the engine spins fast but you almost aren't moving?
2 very different things...
Engine turning high rpm and "going nowhere fast" (not moving a lot of water):
Actually the prop can be slipping long before 2000 rpm . Once the rubber insert starts slipping a little at high load, it can progress to slipping all the time and eventually the prop just falls off. It doesn't take long from just some high speed slip to slipping any time the engine is in gar in the water.
I've seen a couple where you could have the outboard in gear and easily hand turn the prop without the engine turning.
Engine failing to get up rpm can be a LOT of things.
Quick basic check for bent shaft. Put it in neutral and spin the prop. Watch the center of the shaft to see if it looks like its wobbling. No easily visible wobble and its PROBABLY not bent.
To be sure you have to pull the prop and use a dial indicator to check the shaft "runout"
If its bent... you won't have long before the bearings go out and you hear bad grindy noises.
GA_Boater
You already have a thread about this. Please don't start multiple threads on the same problem - http://forums.iboats.com/forum/forum-rules-and-guidelines/9938375-photo-upload-tutorial
You never said how the shaft got bent and the prop got spun. So you have at least two problems to fix.
The two threads are being merged to keep the questions and advice in one place.
nellie1
thanks for heip. i am not boat mechanic but i am inclined.. am a machinist , lets have a vote can i pull lower unit and change shaft without experiance.. be nice
