Hi I did a dumb mistake. i removed the shift cradle screw on my 2005 25hp Johnson Long shaft.
the screw will no go back in.
How do i put it back in..???? I just looked online at an owners manual all it says about this screw is DO NOT REMOVE. Thats was my mistake.. Help how Do I put back in?
OK I tired wiggling the shift arm.. using picks etc.. When I finally get it aligned.. it wont shift out of gear.. so its in wrong... reading other post it seems I have to open the Gear case now..?? so I have to remove prop, gears , clutch dog...I am trying to figure out how removing the lower unit will help me re-aling everything?
I just go the service manual its kinda vague about it..just says do no remove..
I have never open a gear case before..
i have removed lower units to replace water pumps..
but I need advise on what should i attempt and how to do it the right way on this motor.. its a LONG shaft too.
see video as well
http://youtu.be/ZsLKBXxHotA
see video as well
