help going carb crazy!!!!!
jbyrd1364
I have a 1989 bayliner capri w/ force 85 hp and am having carb issues. first off the boat sat for approx ten yrs and she still runs after cleaning adjusting and tinkering with just about everything, but the problems at hand now are just with the top carb spraying gas out of relief holes.
things i have done include
cleaning entire fuel system, rebuilding of fuel pump, i have had carbs off numerous times cleaned and checked float levels inspected needles and seats, installed external inline filter but nothing seems to help it just continiously sprays gas and will not idle unless idled up and then is a pain to get into gear before it chokes
thanks in advance for any help JUSTIN
slow426
Re: help going carb crazy!!!!!
had the same prob.drop the bowl and clean needle n seat .your float is proly sticking.
sidenberg
Do not use carb cleaner as it will ruin the rubber seats or needle tip.
jbyrd1364
have already cleaned needles and seat with throttle plate cleaner which said was safe to use on rubber components and also when i took them off yesterday they were clean
pnwboat
Either the needle valve is bad, or the float is not a buoyant as it should be. If the float is the dark plastic foam type, they tend to get less buoyant with age so even if you set the float height per instructions, they don't float high enough to close the needle valve. Either set the float just slightly lower (further away from the carburetor body instead of parallel to the body) to compensate, or replace it. The hollow metal brass floats don't have this problem.
jbyrd1364
the tips of the needle valves look good still red in color and are clean of any debris and pits also have the brass floats
jbyrd1364
i have checked the floats and they all float and do not have any holes
Frank Acampora
The carb spraying gas out the vent holes can only mean it is getting too much gas. Remove the carb and turn it upside down. Now blow through the inlet fitting. The weight of the float alone should seal the needle and seat. If you can blow any air into the carb: Quit playing with it and replace the needle and seat--no matter how they look.
jbyrd1364
alrighty thanks any tricks to getting the needle seats out?
Frank Acampora
If they are screw-in type, just use a (I think) 3/8 wrench. (Might be 5/16 or 11/32 I forget those kind of things and just check when I need to.) If they are press-in you need to remove the needle and screw in a self tapping screw, then use it to pull out the seat.
jbyrd1364
thanks alot will update as soon as i get the parts and install
jbyrd1364
well rebuilt carbs with new needles and seats and problem fixed took her to the lake this past weekend and she ran like a dream thanks for all the help
