Help First Boat
Taz59
Hi Guys
Going looking at my first boat and need some help on what to look for,It has 1995 3LTR Mercruiser Engine with Alpha One.
What things should I look out for and what should I check.
Thanks
Taza
zbnutcase
Re: Help First Boat
The best advice I can give is read the owners manual!
basspirate
Re: Help First Boat
i would check your bank balance. make sure you have plenty of extra money as even the best used boats will cost you extra money
Taz59
Re: Help First Boat
Not got boat yet going looking this Saturday,just after some sort of check list
Taz
basspirate
Re: Help First Boat
since this is your first boat i would hire a marine surveyor. let them figure out the problems. the few hundred dollars it will cost you will pay off if you get stuck with a lemon boat.
stonyloam
Re: Help First Boat
Absolutely without a doubt the best advice you are going to get!!:D
carcraze
Re: Help First Boat
Make sure you get to do a water trial too many things can not be seen until it is running under load in the water and I second the surveyor. I am learning the hard way on those points.
Fishermark
Re: Help First Boat
The surveyor is a great idea - OR someone who knows boats going with you.
The big thing many over look is the structure of the boat itself. They look at the paint and the upholstery - even the engine and outdrive - but fail to consider the integrity of the hull. The floor and transom - things like that.
