mountforever
Thread starter- Joined
- May 28, 2009
- 12
I have a 22' cuddy cabin that runs off of two Group 31 batteries. One battery for the starter motor and one for the electronics. They both run to an AB Switch. This past weekend I flooded the engine trying to restart while out fishing. I kept cranking and cranking and drained the starter battery. I flipped it over to the electronics battery and it turned over. When I got back to the dock I switched my two batteries back. Unfortunately when I went to hook up the starter battery I put the rings on the wrong terminals (they aren't labeled). Big sparks flew when I put the negative cable on the positive of the starter battery. Now my fuse panel won't turn on. The engine however does start and the hydro works. The electrics battery does go through a buss panel and then eventually runs into this. http://bluesea.com/products/4376
Is it even possible to blow out every one of the circuit breakers on here by just putting the negative cable on the positive? Or am I missing something here. I've tried unplugging and resetting the push button breakers on the fuse panel. I'm at a loss here. any help would be appreciated. Thanks!
