ilikefishing
Thread starter- Joined
- Aug 17, 2018
- 4
Purchased two motors with a used boat to restore. The other motor is a 85 remote steer Evinrude 30hp model E30ECOLA and it runs fine.
The one I am having problems with is the tiller steer 1986 E30TELCDM 30hp. It has a push button primer and if I push the button once it starts up, It only runs smooth at low idle, as I power it up it hitches, misses for lack of a better description. I have rebuilt the carb (I have a nagging fear that I may not have set the float right) I have checked spark and swapped out coils, wires and plugs with the known good motor. I can take the carb off if that is recommended, just a pain. Any other ideas are also welcome. Oh... compression is 95 on both cylinders
Thanks
Thanks
