Re: Help dating a Chrysler 6hp
Hi giganta<br /> What Chief say's is correct. I have no way of telling what you actually have, I just look up the numbers you provide in the book. The model 64HC started in 1974 with ser# 3001. Chrysler made this model until 1976 starting with ser#7300. 1975 models ser#'s started at 5401. Your ser# is 7003. There is nothing really special about your motor. The controls should be stright forward. On the front cowl there shoulb be a choke knob, a bonnet latch and a forward-neutral-reverse shift lever. The throtle control should be located on the tiller arm.
